can you swap heads from 99 to a 01-3.3
Old Feb 5, 2010 | 05:08 PM
Schuey's Avatar
Schuey
Default can you swap heads from 99 to a 01-3.3
buddy of mine is wants to swap heads on his minivan.. what issues would he have if he could swap heads from the 99 to 01 caravan or is it even possible?
thanks,
The Middle Man lol
Schuey
Old Feb 5, 2010 | 06:02 PM
master tech's Avatar
master tech
Site Moderator & Tech
You could run into some problems using the cylinder heads off of a 99 engine. You need to remember that the 1999 is a NS body and the 2001 is a RS body. There be some changes such as coolant passage and the manifolds bolting up to the heads and the valve covers. You could have the same problem if you wanted to replace engine. Why not just find the parts you need off of a RS body, They made this body from 2001 to 2007. Then 2008 to 2010 its now the RT body.
Old Feb 6, 2010 | 09:25 AM
Saabu2's Avatar
Saabu2
Default body model years
are 99's and '00's the same body type?
thanks,
Wayne
Old Feb 6, 2010 | 09:37 AM
Tizzy1's Avatar
Tizzy1
yes, NS is 1996 - 2000 model years.
