I need to replace the rack on my 03 caravan sxt. 3.3 liter, and can't find anything on line for this. Is this going to suck doing on the ground because the cradle may need to be dropped or does the rack slide out the side without any problems. Thanks
you take the black pan off the craddle and it comes down. I'll print some R&R info.
STEERING GEAR
STEERING GEAR
- Remove the cap from the power steering fluid reservoir.
- Using a siphon pump, remove as much fluid as possible from the power steering fluid reservoir. Use care not to damage the filter mesh below the fluid surface.</B> CAUTION: Locking the steering column in the straight-ahead position will prevent the clockspring from being accidentally overextended when the steering column is disconnected from the intermediate steering coupler.
- Position the steering wheel in the STRAIGHT-AHEAD position. Lock the steering wheel in place using a steering wheel holding tool.
- Move the carpet away from the dash seal cover at the base of the steering column on the lower dash panel.
- Remove the screws securing the dash seal cover to the lower dash panel. Lift the dash seal cover from the lower dash panel and position it so the intermediate shaft coupler roll pin can be accessed.
- Remove the intermediate shaft coupler roll pin. To do so, install Remover/Installer, Special Tool 6831A, through the center of the roll pin, securing it with the knurled nut. Hold the threaded rod stationary while turning the nut, pulling the roll pin out of the intermediate coupler.
- Slide the intermediate shaft coupler from the steering gear pinion shaft.
- Raise and support the vehicle.
- Remove both front wheel and tire assemblies.
- If the outer tie rods need to be transferred to a new gear, loosen the tie rod jam nut on both sides of the vehicle.
- On both sides of the vehicle, remove the nut attaching the outer tie rod end to the steering knuckle. Remove the nut by holding the tie rod end stud with a socket while loosening and removing the nut with a wrench.</B>
- On both sides of the vehicle, remove the outer tie rod from the steering knuckle using Puller, Special Tool C-3894–A.
- Pull outward on the right side tie rods (or push inward on left side tie rods) until the internal stop is met. This action to shorten the length of the left side tie rods will be important in removing the gear from the vehicle in later steps.
- Remove the NVLD assembly.
- Remove the emissions vapor canister.
- Remove a single hose at the power steering cooler and allow the fluid to drain.
- Remove two bolts attaching the power steering cooler to the cradle crossmember reinforcement.
- Remove the screws fastening the pressure and return hoses to the rear of the cradle crossmember.
- Unscrew the tube nuts securing the power steering pressure and return hoses to the power steering gear. Remove the hoses from the gear.
- Remove the three bolts and nuts mounting the steering gear to the front suspension cradle crossmember.
- Lower the steering gear far enough for the pinion shaft to clear the cradle crossmember, then shift the entire steering gear assembly toward the passenger side of the vehicle until the left outer tie rod end can be lowered through the center opening in the cradle crossmember reinforcement.
- Remove the steering gear by sliding it down through the opening in the center of the cradle crossmember reinforcement.
- If necessary, remove the outer tie rod ends from the inner tie rod threads. Count how many rotations it takes to remove each outer tie rod for installation reference. Putting the outer tie rods back on the same distance will get the toe setting somewhat close to specification before the wheel alignment is performed.
Quote:
YES!Originally Posted by mike bloom
I need to replace the rack on my 03 caravan sxt. 3.3 liter, Is this going to suck
But if it was easy, everyone could do it.
These are the things that make us better than everyone else!
Good Luck,
EZ1
