97 caravan cooling problem
Old Mar 7, 2010 | 10:36 AM
Heavy_D508's Avatar
Heavy_D508
Default 97 caravan cooling problem
well i think my relay is no good, the fan turns on if i put 12v directly but, if i leave it the way it is then the car starts to over heat, also i read that there is a relay that cost 60 bucks or more, but can i use one of my own relay and wiring it up? or will there be too much heat and melt the relay? the factory relay that came from factory has some special thermo 5 compound the keep it cool on the chassis, and maby i thought i could use a universal relay instead of the factory. maby some one could help me out on that
Old Mar 7, 2010 | 12:13 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would replace the relay with a factory relay. But i would also ck with local dealer, because there was a recall for the fan relay and a flash.
Old Mar 7, 2010 | 09:13 PM
Heavy_D508's Avatar
Heavy_D508
yea i seen that too, now if i was to bring it to a deal would they replace it for no charge? i never brought a car to a dealer, i just mostly change the stuff
Old Mar 7, 2010 | 09:52 PM
master tech
Here is what you do. Send me the last 9 of your vin on a PM, not on the open forum. I can tell if you ever had the recall done and if there is any other recall too.
