Crazy Speedo causes crazy accelerating
Old Mar 10, 2010 | 02:36 PM
thaddy1978's Avatar
thaddy1978
Default Crazy Speedo causes crazy accelerating
When my 01 Grand Sport is not running the speedo sits at 9 mph. When running and not moving, my speedo needle goes crazy, flipping back and forth. When doing this, if I try to pull out of my driveway (in D or R) I get jerking out of the van, which then smooths out when I get going.
I have changed the in/output speed sensors with no change in behavior...however it did get rid of all of the trans codes that were indicative of speed sensor issues.
It was not until I was experiencing the speedo issue and jerking of the van, that it constantly showed 9 mph over.
Any ideas on what is causing this or what I can do to fix it all?
Old Mar 10, 2010 | 05:45 PM
Tizzy1's Avatar
Tizzy1
You are going to need to get access to a scan tool to see what is causing the issue. It could still be in the transmission, the PCM or the cluster. That is a tough problem to just guess at because it could be so many different things.
Old Mar 10, 2010 | 09:00 PM
master tech's Avatar
master tech
Site Moderator & Tech
I agee as well.
Old Mar 10, 2010 | 11:36 PM
thaddy1978's Avatar
thaddy1978
I take it that you mean a snapon-type scanner, vs. the Autozone scanners...? Because it has been scanned by one of those.
Old Mar 11, 2010 | 10:26 AM
Tizzy1's Avatar
Tizzy1
You need to be able to read sensors while driving the vehicle to determine what is causing the speedo to malfunction.
