95 Grand Caravan Check Engine Code 41
Old Mar 16, 2010 | 10:19 PM
Woodrow's Avatar
Woodrow
Default 95 Grand Caravan Check Engine Code 41
My 95 Grand Caravan stopped charging the battery. Check engine light is on showing code 41. I stopped by Kragen and indicated that Alternator is not charging battery. Battery is good. I pull the alternator out and had them check is on their machine in the store and it is working properly.
I know what code 41 means - Open or shorted condition on Alternator field control circuit.
Does any one have any ideas as to what is causing this problem and how do I fix it?
Thanks,
Woodrow
Old Mar 16, 2010 | 10:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The problem could a wiring or the engine controller.AKA Spec controller. Code 41 is also a transmission code too, LR solenoid circuit.
Old Mar 17, 2010 | 10:40 AM
Woodrow's Avatar
Woodrow
Thanks for the info. How do I test the vaious components to figure out which one is defective?
Old Mar 17, 2010 | 10:42 AM
perry's Avatar
perry
check the wire connector where it plugs into the alternator.
