99 grand caravan turn signal issue
Old Mar 19, 2010 | 12:32 PM
FLASHJR's Avatar
FLASHJR
Default 99 grand caravan turn signal issue
Hi I am hoping someone can help, have a 99 grand caravan and after the van is drove 4 or five miles and you turn the left turn signal on it stays on does not blink just locks up and keeps the lights on steady. also if you shut it off the left rear light stays on. The bulbs are all good. Any help would be great.
thanks
Old Mar 19, 2010 | 01:22 PM
Tizzy1's Avatar
Tizzy1
It might be the flasher, it is in the fuse / relay panel down by the brake pedal. When the light stops flashing, try tapping on the flasher to see if they start again. It is the taller of the relays in the panel.
