2008 DGC 4.0 A/C Low side port
Old Mar 19, 2010 | 09:49 PM
jmkinc's Avatar
jmkinc
Default 2008 DGC 4.0 A/C Low side port
Does anyone know where the Low side a/c port is on the new 4.0 liter minivans?
Old Mar 19, 2010 | 11:48 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Two refrigerant system service ports are used to recover/recycle/evacuate/charge and test the A/C refrigerant system. Unique sizes are used on the service ports for the R-134a refrigerant system to ensure the system is not accidentally contaminated with R-12 refrigerant or service equipment used for R-12 refrigerant.
The high side service port is located on the A/C liquid line near the front of the right front wheel well. The low side service port is located on the A/C suction line near the A/C expansion valve at the dash panel. Both the high side and low side A/C service port valve cores are serviceable.
Each of the service ports has a threaded plastic protective cap installed over it from the factory. After servicing the refrigerant system, always reinstall both of the service port caps.
Old Mar 20, 2010 | 12:00 PM
jmkinc's Avatar
jmkinc
Do you have to remove any components to access it?
I looked and I can't seem to find it.
Old Mar 20, 2010 | 12:40 PM
Tizzy1's Avatar
Tizzy1
Low side port
