96 caravan BCM question
Old Apr 13, 2010 | 08:51 PM
Bluestreak95's Avatar
Bluestreak95
Default 96 caravan BCM question
Ok so im guessing my BCM is going bad cuz my dims dont work and my headlight light it always on when my headlights r turned on also my wipers work when they want to...so i have sum question about the BCM...
when im looking/getting a BCM does it need to be programmed or anything or is it just plug n play from any 96-98 Caravan?
also is there a easy way in finding out what part number is on your BCM if needed?
Can my van run without a BCM if needed?
Is there any way to test the BCM to see if its bad?
Old Apr 13, 2010 | 09:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
No the van won't run without the BCM, Two ways getting the part number. Look at pn number on the BCM or call the dealer and give them your vin number.....Last 9, this way they can tell you the right part number and price.
Old Apr 13, 2010 | 10:47 PM
Bluestreak95
thank u very much man how much does a new BCM run for these days....
Old Apr 30, 2010 | 10:00 AM
Bluestreak95
went to dealer they gave me 6 diffrent numbers so i guess ill have to take it out n get the number
