1990 Caravan Crankshaft Seal
Old Apr 23, 2010 | 07:50 PM
BonesMachine's Avatar
BonesMachine
Default 1990 Caravan Crankshaft Seal
I have a 1990 Caravan with the V6 3.0 engine. It has an oil leak coming from the right front of the engine. It leaks a little while running and leaves a small trail of oil when driving. It stops leaking quickly after the engine is shut off. 3 questions:
1: This sounds like a crankshaft seal right?
2: I haven't picked up a Chilton's manual but was wondering if I have to take off the timing belt cover to fix this.
3: Any links to full steps on this procedure without picking up the Chilton's manual.
Thanks
Old Apr 23, 2010 | 11:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
its more than likely the right cam shaft seal, and yes the timing belt would need to come off. I don't if chilton manual would have that information.
