Tranny fluid change 62TE
Old 06-11-2011, 11:38 AM
keaunym's Avatar
keaunym
keaunym is offline
Originally Posted by DodgeCaravan2010SXT
well fill hole is the dip stick hole. its covered with a black cap that says do not remover. dealer something or other.
Excellent. I'll take a look. In case I don't find it, which side of the engine should it be?
Old 06-11-2011, 11:41 AM
keaunym's Avatar
keaunym
keaunym is offline
Also, is it tamper resistant?
Old 06-11-2011, 01:07 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
DodgeCaravan2010SXT is offline
not tamperproof. its on the right side driver.
Old 06-11-2011, 11:16 PM
keaunym's Avatar
keaunym
keaunym is offline
Perfect! Found it exactly where you said.
Now I have to figure out the exact same fluid that was used since this is actually an '09 VW Routan SEL (same as Dodge Caravan except body, interior, and suspension). Not sure if VW decided to use the exact same fluid or not, or if they used the MOPAR ATF+4, but with some extra additive. I'll see what dealer service says. Thanks again.
Old 06-11-2011, 11:30 PM
DodgeCaravan2010SXT
same fluid atf + 4. now the only thing to worry about is that you need 2 things. special tool thats actually a dip stick and a scan tool to check the transmissions fluid temperature. using a graph they have tells where the dip stick level should be. little hard for a home backyard mechanic to figuire out.
Old 06-12-2011, 03:57 AM
keaunym's Avatar
keaunym
keaunym is offline
What if I let the vehicle and replacement fluid sit overnight in the garage. Next day, I remove whatever I can throught the dipstick hole, measure exactly, then replace the volume I removed. Since this is presumably "lifetime" fluid in a "sealed" transmission, the level shouldn't be dropping such that I need to figure out the most appropriate new level. Same since I won't be dropping the pan and replacing the filter making it impossible to measure precisely. I'm only at 15.5k and I'd only be doing this as preventative every other oil change or so.
Any reason this is actually a bad idea. Any input appreciated.
Old 06-12-2011, 04:01 AM
keaunym's Avatar
keaunym
keaunym is offline
I should mention, this is essentially what I have been doing with a Volvo S60 and V40 with no problems. Only difference is that there is a drain plug and here I assume I'll have to use a large syringe or pump and tubing through the dipstick hole.
Old 06-12-2011, 12:09 PM
DodgeCaravan2010SXT
every other oil change be waste in my view but every 20km or more just adds a safety
Old 06-13-2011, 03:52 AM
keaunym's Avatar
keaunym
keaunym is offline
Took a small sample today. At only 15k miles, she ain't too pink anymore.
Old 06-14-2011, 10:08 PM
keaunym's Avatar
keaunym
keaunym is offline
The motor oil dipstick works perfectly and the proper level can be determined using the motor oil dipstick while the emergency brake is engaged and the vehicle is in gear.
Quick Reply: Tranny fluid change 62TE
