2000 Caravan slips into neutral while in drive
Old May 16, 2010 | 01:07 AM
salmonz's Avatar
salmonz
Default 2000 Caravan slips into neutral while in drive
My 2000 Dodge Caravan 3L slipped into neutral while in drive tonight. This happened twice before in the past month. I changed it to reverse and same thing, no movement and sounded like it was in neutral with the engine revving when applying the gas. 15 seconds later, the van moved, then after it was ok.
Is my transmission fubar'd?
Old May 16, 2010 | 11:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
Ck the fluid level first, and did the ck engine ever come on? You maybe just low on fluid.Does you van have 3speed trans or the 4 speed?
