Tires and drift
Old May 19, 2010 | 04:07 PM
bullheadpond's Avatar
bullheadpond
Default Tires and drift
i have a 2008 grand caravan sxt. i had new tires put on it (coopers) and this is the second time i had it algned and it drifted to the left. The first time the mechanic said they swapped the tires from left to right on the front. Now they are saying i will have to do the same thing since it is drifting to the left again after tire rotation and alignment.
The first time they swapped the tires the drift did go away.
Is this normal or is something wrong with these tires .Which they also sold me.
To me it dosen't make much sense to rotate the tires if they are just going to move them again the next day.
Old May 19, 2010 | 08:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did have a front wheel alignment done or a 4 wheel? And do you still have the print out. If you still have the print out post it.
