2006 grand caravan a/c problem
Old May 24, 2010 | 06:03 PM
scootermiller's Avatar
scootermiller
Default 2006 grand caravan a/c problem
i got a 06 grand cravan with dual a/c & heat .
with a/c on high front & rear in the fron the passenger side is cold & driver side is hot , rear is ice cold . I also noticed at night with the lights on only half of the tenp control lights up which is the pass, side please advise thanks....
Old May 24, 2010 | 10:14 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
First you need to have the HVAC ck for any codes. You could have a problem with the blend doors, actuator or the control head.
Old May 25, 2010 | 03:23 AM
scootermiller
Default 06caravan a/c problem
i had checked the obd and a code came up p0406 but thats came up for the egr , i had it replaced and and checked again no other codes came up. if its the door's or the accuator how do i check them and how do i get to them please advise thanks
