Code 37, 32
Old May 26, 2010 | 08:02 PM
ianis's Avatar
ianis
Default Code 37, 32
Hi all,
New to this site and I am looking forward to some input.
I have a Dodge Caravan 1995 3L
I did a key code test and received this codes 37 and 32 .
Code 37 talks about PTU or torque converter clutch solenoid , where is this solenoid located and what does it involve in changing it? Are there any links or pics on the internet of the PTU?
Code 32 talks about EGR solenoid circuit. I have changed the backpressure transducer assembly but nothig changed
Any input on how to fix this issues?
Old May 26, 2010 | 10:13 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
If you have a 3 speed transmission, ck the connection going into the transmission case. it will be on the left of the dip stick tube. That is your lock up solenoid. If the connection is good, replace the lock up solenoid. You will need to remove the valve body to replace it. Have you tried to clear the codes? You could have a plugged egr tube or port.
