02 GC Maintenance History, 03 To Present
Old May 27, 2010 | 01:22 AM
2therock's Avatar
2therock
Default 02 GC Maintenance History, 03 To Present
This is the maintenance life of an 2002 Grand Caravan Sport made in Canada and delivered to Avis Rental and then it Car-max in GA @ 7,948 miles.
You guys are going to recognize some of the common things.
She has a 3.3 Flex, Cloth, drum rears and came on steel wheels. Dual AC, manual doors, key-less entry, trip meter in the over head with home link, lots of speakers.
9/01/03 Purchased from Carmax Kennesaw GA @ 7,948 miles.
52 miles later @ 8000 miles a JVC KD-S590 AM/FM CD player was installed by Bestbuy.
To shorten this list, JiffyLube did the oil changeds regularly @3k or so throught the ownership.
11/16/04 @22,927 It went to Chrysler for recall work, Power sterring hose.
12/8/04 @23,583 miles, Brakes vibrate and noisy, surfaced rotors and added ceramic pads.$201.00
7/12/2004 @18,351 Alternator. Warranty.
3/3/05 Went in for recall #D48 (Radio gets wet from condensation via vent)
4/21/05 @26,422 They hit something in road that punctured tank. Had to tow in. New tank & pump, $617.00.
9/2/06 @ 38,616 New pads, truned rotors.Rotate Resurfaced rear drums. $279.00 at Goodyear.
9/14/06 @39,186 drums were smoking, readjusted. No charge.
10/7/06 @39992 Napa Battery $79.00.
11/24/06, @42427 2 tires , 4 wheel align, $292.22 at Goodyear.
1/20/07 @44030 Backing up Brakes squealing left front. Going forward both grind when braking. Scuff pads and turn rotors. No Charge.at Goodyear.
12/26/07 @54514 Loss of power with moaning noise. New rack and pinion, alignment, and power sterring flush, decarbonization fuel system, warning of about PS pump in furure. $1219.00.at Goodyear.
5/31/08 @59388, Fuel pump & filter, Pads and rotors turned, spark plugs, differential service, air filter, Trans service, anti freeze flush, $1,232,35 at Goodyear.
6/10/08 @59514, Not shifting properly, creaking in hard turns,= Reman right drive axle, 2 new struts, w/new mounts alignment, 980.35 at Goodyear.
12/6/08 @63964 power steering noise, New hoses and flush, align ref thrust angle. $215.95 at Goodyear.
1/23/09 @65388, Brakes grinding, smelly.Rear drum overhaul. Fluid flush. Intake manifold gasket. $854.48 at Goodyear.
3/17/09 @66856, AC compressor, Dryer, expansion valve, belt, $852.70, at Goodyear.
6/17/09 @69598 Brake lights, 3rd brake light, l tail light, 21.93, at Goodyear.
9/11/09 @71429 Emissions, squealing brakes, wheel align thrust line, 4 tires, balance, both front brake hoses, fluid change, rear wiper, 1362.08, at Goodyear.
1/2/10 @74075 Window washer not working, oil change, new water pump, thermostat housing, radiator cap, $564.05, at Goodyear.
4/24/10 @76580, Lube, blower motor resistor, Run diagnostic, replace right axle. $462.93, at Goodyear.
============ From this point the Maintenance is in my care =========
5/25/10, I buy @ 76677 miles and put in a monster battery since the current one was corroding and 4 years old.
6/10/10 Remote starter system installed Avital Brand.
6/14/2010 Pioneer DEH-P5200 HD & XM receiver installed.
7/29/2010 Front brakes and Rotors. Advanced Auto lifetime parts @107947 miles
8/5/2010 The Advanced Auto ceramic pad replacements of the OE bi-metal does not agree with the Wagner rotors and swapped out via lifetime warranty replacing with bi-metal. Better but not bullet proof.
1/27/2011 Sway bar bushings, Moog Blue @ 92,000 miles.
12/2011 Oil pan gasket replaced. @ 110,000 miles
9/6/2011 Sway bar bushings installed. OE with inserts. @ 103,069 miles
9/9/2011 Repaired starter with new solenoid contacts. @ 103,069 miles
12/9/2011 Front Brakes serviced again. Did the warranty rotor and pad swap with Advance Auto @ 116052 miles.
3/12/12 New Michelin Defender Tires @ 113,148 miles.
3/12/12 Aluminum wheels By Sport Edition, F2 model from TireRack.com.
3/12/12 Tire pressure monitoring by Orange Electronic (P409S)
4/5/2012 Drivers Side CV Axle replaced. @114,640 miles
9/2012 Van broken into and theft attempt made. @ one hundred twenty three plus miles
Used steering column eBay purchased for the Key switch cast metal housing, $75.00 shipped, saved $300.00 + over a new one.
  • New SKIM module.
  • Dealership flashed skim.
  • Viper 5704 Security and remote start installed.
10/1/2012 European Chrysler Grand Voyager Zizala quad headlights at one hundred twenty three and two hundred miles.
10/23/2012 Sound system upgrade. All Memphis Power Reference series speakers in all 6 places. Dash 5.25 coaxial, doors and rear 6X9" Tri-axials, on an Alpine Amp, 10" Sub woofer in a their box on a PowerBass Amp. @ 124,000 miles
11/12/2012 Brake Drums turned. Could feel slow roll to a stop pulsation. Shoes OK. Pulsation gone. @ 125,200 miles
12/15/12 Front Brake upgrade to StopTech premium cryo treated and drilled rotors with Raybestos advanced technology pads. Fluid flushed.@ 125,245 miles
12/22/12 New battery, the largest I could get an 800 Cold Cranking Amp replaced under warranty. 125,330 miles
12/30/12 Transmission shift solenoid pack @ 125,393 miles
123
Old Mar 30, 2012 | 04:23 PM
2therock's Avatar
2therock
****** EDIT 12/26/12********
Moved info to OP
