2000 Caravan: Instument Cluster Doesn't work.
Old May 29, 2010 | 06:38 AM
tg5398's Avatar
tg5398
Default 2000 Caravan: Instument Cluster Doesn't work.
The instument cluster has worked a few times, but for the most part nothing. What should I be looking for?
Old May 29, 2010 | 01:07 PM
Tizzy1's Avatar
Tizzy1
If everything else in the vehicle works, I'd start looking at the printed circuit board on the back of the cluster. Try unplugging it for a few minutes and then reconnecting it. If it starts to work, the board is bad. Could be bad either way.
Old May 31, 2010 | 12:21 PM
tg5398's Avatar
tg5398
Thanks! I'll check that out.
Ted
Old Jun 1, 2010 | 03:57 PM
dspii's Avatar
dspii
New Member
Chrysler has a known issue with cold soldier joints on the ribbon cable at the circuit board. If you look close, you can see the bad soldier joints, they will looked cracked. Just touch up with your soldering iron and a little solder. Should fix your problem...at least it did on my 97 Grand Caravan.
Old Aug 12, 2010 | 06:39 AM
tg5398's Avatar
tg5398
Thanks, Sorry I left this open. The advice was right on the money. Got it.
