96 dodge caravan ac problems
Old Jun 6, 2010 | 12:48 AM
rob_5's Avatar
rob_5
Default 96 dodge caravan ac problems
Put a new ac belt on. Then found out it was out of freon filled it with a 2 cans. Now the compressor is still cycling put blowing off pressure on the pressure valve on on the compressor. And also the clutch freezes for a min then starts again. Any ideas? Possibly put a new compressor on?
Old Jun 6, 2010 | 12:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The H-valve may have a blockage, causing the pressure valve to blow out freon. Or you have too much freon in the system.
Old Jun 6, 2010 | 03:46 PM
rob_5's Avatar
rob_5
ok Ill try the freon first and see if that works!! where might the h-valve be located? Also doesnt seem to cool like it should?
Old Jun 6, 2010 | 04:38 PM
vabear's Avatar
vabear
Default AC issue
Do you have a set of gauges? If so you want to see (on a +80 F day) 30-40 PSI on the low side and 190 psi- 220 psi on the high side.
Old Jun 6, 2010 | 10:01 PM
master tech
The H-valve looks like a block with lines going into it. Passenger side going towards the bulkhead/firewall.
