AC Problem
Old Jun 8, 2010 | 10:52 AM
paul74's Avatar
paul74
Default AC Problem
Hello to all,
I have a 2000 Dodge Caravan 2.4v and the issue with the AC I have is that when I switch it to ON and the only thing that turns on is the compressor and not the "blower." When I switch it to off the compressor stays on the the 2 AC light buttons stays on. I'm thinking that maybe its a switch problem, Relay problem or the actual blower went bad.
I need to get this resolved because the heat in Miami, FL. is the pits....
Any advice will be helpful
Old Jun 8, 2010 | 11:17 AM
Tizzy1's Avatar
Tizzy1
So the blower motor doesn't work in the car? Auto temp or manual? Does it have rear a/c? When you turn the blower motor switch to off the a/c button led stays illuminated?
Old Jun 8, 2010 | 12:55 PM
paul74's Avatar
paul74
Its a manual, It does NOT have AC in the rear and yes the a/c button led stays illuminated but no air and compressor activated. Checked all the fuses and they're all good....
Thanks for the reply...
Old Jun 8, 2010 | 03:22 PM
Tizzy1's Avatar
Tizzy1
Blower motor diagnostics is pretty straight forward. Power is supplied to the blower motor and then it goes through a resistor and then to ground. the blower motor switch controls which wire gets grounded. The resistor is under the hood by the right strut tower and goes bad quite frequently usually needing a connector when it is replaced. Start at the blower motor, if you have power on both wires then you don't have a good ground.
