2002 caravan engine noise
Old Jun 12, 2010 | 02:10 PM
disop's Avatar
disop
Default 2002 caravan engine noise
makes loud almost grinding sound on idle also boiling sound after turning off coolant is right level and temp gauge reads fine
Old Jun 12, 2010 | 04:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Pull off the fan belt and see if the grinding sound is gone. I most case's the water pump bearing goes bad a makes a grinding sound.
Old Jun 12, 2010 | 05:26 PM
02b4c's Avatar
02b4c
Default 2002 dodge se scan code ev need help
just bought 02 se 3.3 scan tool says ev pointers of where to look for problem?
Old Jun 15, 2010 | 10:25 AM
disop's Avatar
disop
just had it looked at, was told it is the a/c compressor starting to fail. Does this sound right
Old Jun 15, 2010 | 08:28 PM
master tech
Sure it could.But did you have the water pump looked at too?
Old Jun 16, 2010 | 10:26 AM
disop's Avatar
disop
thanks for the info, will make sure before I ok any work.
