08 GC Check Engine Light On
Old Jun 18, 2010 | 05:34 PM
champr's Avatar
champr
Default 08 GC Check Engine Light On
I have an 08 GC with 3.8L engine. The check engine light came on last Sunday. I removed the gas cap and reinstalled. Checked the codes and from the web it said the gas cap was the most likely culprit. I can't remember the code now. I reset the code by disconnecting the battery. The light was off when I reconnected the battery and did a test drive.
Fast forward...no light all week until today. Check engine light came back on, only now there are no fault codes when I check.
Any one have any ideas? Thanks for the help.
Old Jun 18, 2010 | 09:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
How did you ck the van for codes?
Old Jun 18, 2010 | 10:04 PM
champr's Avatar
champr
Using the on-off-on-off-on method and reading from the odometer. Now it just shows dashes and then says done.
Old Jun 18, 2010 | 10:43 PM
master tech
In most case's , you should have a stored code in the pcm. And you don't remember the code you had before? Maybe P0441 or P0456.
Old Jun 21, 2010 | 01:30 PM
champr's Avatar
champr
I think the code was P0455. What's strange was the light came back but the code doesn't show anymore. I am thinking of just getting a new gas cap and trying that. Any thoughts.
Old Jun 21, 2010 | 10:08 PM
master tech
If that was the code you were getting, Thats a large evap leak code. Should have the dealer run a evap test. Maybe the evap system either pass fail.
