P1493, P0117 codes at same time.
Old Jun 21, 2010 | 08:17 PM
Uncle Shadetree's Avatar
Uncle Shadetree
Default P1493, P0117 codes at same time.
I have an ongoing problem with my '97 GC Sport 3.3l 2wd. When cold starting, cranks fine, wants to catch, but chugs a few times and stops. Try again and starts, but barely until I gas it for a few seconds. The whole time the battery light and the CEL is on. After driving for a few minutes, the motor will just quit without warning. I can start it right back up. Testing for codes sometimes shows p1493 and p0117, sometimes nothing. Coolant temp gauge stays at min. Replaced ECT sensor, still get codes. Trying to use this forum for help because I've been out of work for 10 mo., any help appreciated!
Old Jun 21, 2010 | 10:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
P1493 is battery volts too high and P0117 is ECT volts too low. I do have pdf files to help you if you want them, I just need a email address to send them to.
Old Jun 22, 2010 | 04:27 PM
Uncle Shadetree
Can you monitor this thread until I get some closure on this problem? I've been spending money on some unnecessary stuff and it's starting to add up.
Thank you!
Old Jun 23, 2010 | 02:47 AM
Uncle Shadetree
Thanks for the pdf's, MasterTech!
These mostly point to a pcm problem. If I have to replace the pcm, do I have to buy that from a dealer? If not, can I flash it myself? I've heard that you shouldn't pick one from salvage.
Old Jun 23, 2010 | 04:54 PM
mfahey's Avatar
mfahey
I had very good luck with this vendor that I found on eBay. You could contact them to see if they have one for your year and engine.
http://cgi.ebay.com/ebaymotors/2000-...ht_4580wt_1213
Old Jun 23, 2010 | 09:57 PM
master tech
If you need to have a flash done, only the dealer can,unless you know someone that works at a dealer.
Old Jun 24, 2010 | 10:56 AM
mfahey's Avatar
mfahey
Actually, I gave them the VIN and mileage of the van and they took care of the flashing. The unit I received was good to go right out of the box. It was only $150 which I figured was a pretty good deal.
Old Sep 21, 2010 | 06:38 PM
mikeees's Avatar
mikeees
Default P0117 code
Would you please send me the pdf file also. I have the same problem! Thanks
Old Sep 21, 2010 | 07:19 PM
mfahey's Avatar
mfahey
It turns out that my luck hasn't been so great with these people. The first one they sent me set some bogus code. They took it back with no problems but now the replacement is setting P601. They now won't do an exchange without sending the defective unit back first which obviously puts the van out of service.
Old Oct 21, 2010 | 04:48 PM
BBELT's Avatar
BBELT
Default P0117, p1493
I am having the same problem in my '96 dodge avenger. Could you send me the PDF files too?
