Timing Belt
I'm not sure where you got these instructions from, but I am trying to replace the harmonic balancer on my 2000 Chrysler Voyager (2.4L). I rented the Chrysler Harmonic Balancer puller tool from Autozone to remove the old harmonic balancer (it worked, after a slight modification), and then rented the Harmonic Balancer Installer Kit to install the new one. The installer kit does not have the adapter piece to match my crankshaft bolt thread though, so I am not sure how to install the new harmonic balancer (I've read many places not to either hammer it in or to install w/ crankshaft bolt).
So, what does the procedure say about how to perform this installation? I have the Haynes manual, with offers no instruction.
Removal and installation instructions from the service manual........
CRANKSHAFT DAMPER
REMOVAL
Remove accessory drive belts. Refer to COOLING SYSTEM for procedures.
Remove crankshaft damper bolt.
Remove damper by using Special Tool 1026 and Insert 6827 - A Crankshaft Damper - Removal
INSTALLATION
Install crankshaft damper using M12 1.75 x 150 mm bolt, washer, thrust bearing and nut from Special Tool 6792
NOTE: Lubricate the threads of the M12 1.75 x 150 mm bolt before beginning to press the damper on.
Install crankshaft damper bolt and tighten to 142 N·m (105 ft. lbs.) Crankshaft Damper - Installation
Install accessory drive belts. Refer to COOLING SYSTEM for procedures.
CRANKSHAFT DAMPER
REMOVAL
INSTALLATION
CRANKSHAFT DAMPER
REMOVAL
INSTALLATION
CRANKSHAFT DAMPER
REMOVAL
INSTALLATION
