Cruise Control
Old Jun 26, 2010 | 05:46 PM
scrappy13's Avatar
scrappy13
Default Cruise Control
I have a 1997 Caravan. My cruise control has stopped working. The light will not even turn on. My horn still works so I do not believe it is an issue with the clockspring. I am hoping it is just a fuse or relay issue but cannot figure out which fuse or relay is related to the cruise control. Any help would be appreciated.
Old Jun 26, 2010 | 06:15 PM
Tizzy1's Avatar
Tizzy1
There is no fuse, it is all fed by the PCM. Almost going to need a scan tool to tell the faulty component
Old Jun 26, 2010 | 06:57 PM
sapporo's Avatar
sapporo
it sure can be the clockspring. I've had them fail where nothing works, I've had them where the horn didn't work and everything else did, I've had horn but nothing else and so on. so don't discount the clockspring unit you'd actually tested it.
Old Jun 26, 2010 | 10:44 PM
Tizzy1's Avatar
Tizzy1
didn't say it wasn't, probably gonna need a scan tool.
Old Jun 26, 2010 | 11:16 PM
sapporo's Avatar
sapporo
or a basic set of hand tools a $5 Harbor freight multimeter and a wiring diagram and you can determine if the clockspring is the culpret
