04 Grand Caravan Rattle from front when a/c is on at idle
Old Jun 28, 2010 | 02:14 PM
ubenumber2's Avatar
ubenumber2
Default 04 Grand Caravan Rattle from front when a/c is on at idle
Ok I have an 04 Grand Caravan and when you are sitting with it in drive and at a compete stop there is a rattle/vibration type sound coming from around the compressor/waterpump/idle pulley area. It will go away with when you turn off the air or if you give it just a couple more rpms with the a/c on it will go away. Kind of has me puzzled. Doesnt do it driving down the road or even at idle if you are in park
Old Jun 28, 2010 | 10:37 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would pull off the drive belt and inspect all pulleys and the belt tensioner. Also tighten the a/c bracket too.
Old Jun 30, 2010 | 12:40 PM
ubenumber2's Avatar
ubenumber2
I took off the belt off and it seems there is a small amount of play on the water pump pulley , Im going to replace the belt and tension and idler pulley first then the water pump later to see what happens
