01 GC A/C reading high pressure
Old Jul 5, 2010 | 03:22 PM
STWEST's Avatar
STWEST
Default 01 GC A/C reading high pressure
Hello. Replaced the condenser coil, pulled a vacuum and filled the system. Reading high pressure @ the fill port. Need to replace the ex. valves? How to test if I need one or both? Thanks
Old Jul 5, 2010 | 11:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
There two ports,one for discharge and the other is suction. Which one are you getting the high pressure reading?
Old Jul 6, 2010 | 12:02 AM
sapporo's Avatar
sapporo
and how 'high' are said readings?
Old Jul 6, 2010 | 12:08 AM
master tech
Will not know until the member post again.
Old Jul 6, 2010 | 08:10 AM
STWEST's Avatar
STWEST
Thanks for the fast response. readings taken @ the low pressure line (large tube) leading to the compressor. reading now 65 psi. cycles down to 10 when compressor starts.
Old Jul 6, 2010 | 08:47 AM
sapporo's Avatar
sapporo
65 normal for static pressure, 10 a bit low when compressor is engaged.
