1996 100mm and 114mm bolt patterns
Old Jul 22, 2010 | 11:14 PM
Robk1971's Avatar
Robk1971
Default 1996 100mm and 114mm bolt patterns
Hi all,
I have a 1996 caravan with 14" wheels and therefore the 100mm bolt pattern. If I wanted to go to the larger 114" bolt pattern is it just a matter of swapping front bearing assemblies and rear spindles, or is there much more to it? Any info would be greatly appreciated!
TIA
Rob
Old Jul 22, 2010 | 11:20 PM
sapporo's Avatar
sapporo
pretty much but why?
Old Jul 22, 2010 | 11:43 PM
Robk1971's Avatar
Robk1971
Because I would rather run larger diameter wheels. I have to change struts anyway. While I'm in there if it's a simple bearing swap then why not. The rears will be the extra chore I guess but no big thing if it's just the spindles.
Old Jul 23, 2010 | 10:42 PM
sapporo's Avatar
sapporo
well you toss on larger diameter wheels and then you need to have the speedometer recalibrated.
and heck you can get 100mm 16" rims off other chrysler vehicles
I put some daytona 15" rims on my 100mm minivan hubs. looks sweet.
