Question re: front wheel noise on 2004 SE
Old Jul 28, 2010 | 11:39 AM
jkimchi's Avatar
jkimchi
Default Question re: front wheel noise on 2004 SE
Hi Forum: Hoping you could be of assistance with a noise that's been coming from somewhere near my front driver's side wheel.
To describe the noise: it sounds as if there is a bit of a crunching sound (not squeeling), but as if something like rubber was rubbing against something. The sound has been getting progressively louder over these past few weeks (I noticed the noise approximately a month ago).
The sound is apparrent at low speeds and occurs via the rotation of the front wheel. At higher speeds (above 20km/h) the sound becomes un-noticeable.
Any clues to the source of the issue? and what potential solutions could be?
Thank you in advance- JKim
Old Jul 28, 2010 | 01:38 PM
plafleursr's Avatar
plafleursr
Could be the CV joint on driver side axle is giong. My 06 made a couple noises when turning right the just broke, and van had to be towed.
Old Jul 28, 2010 | 08:43 PM
master tech's Avatar
master tech
Site Moderator & Tech
Also could be the axle bearing assy too.
