06 caravan windows switch
Old Aug 1, 2010 | 08:12 PM
2006caravansxt's Avatar
2006caravansxt
Default 06 caravan windows switch
Drivers side window switch broken, not the motor, switch feel different, always goes down, intermittently goes up. How do I remove the panel, and do I have to buy an assembly with all the switches together?
Thanks
Old Aug 1, 2010 | 08:55 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Remove the screws, there maybe two to four of them and then pull from the bottom. Then release the clip that is locking the inside handle on the panel. And yes,you need to replace the as a assy. Its the master switch.
