Leak on top of transmission? With Pics. Where?
Old Aug 14, 2010 | 08:20 PM
Jesse's Town & Country's Avatar
Default Leak on top of transmission? With Pics. Where?
Hello,
Almost forgot, 1997 t&c LXi 2wd, 3.8 liter.
Back around Christmas, I replaced the front pump seal. After finally putting it back together (btw I've had the transmission off at some point of every car I have owned, and this was easily three times harder than any of the others ), it still had a leak (a quart every 2 weeks), so I assumed it was still leaking from the pump seal. I replaced the starter today, and noticed some ATF had puddled up on the case above the final drive, kind of at the back of the transmission (see the picture). It's far enough back that it could not have come from spilling fluid during one of the many top-ups. But I couldn't get a good enough look to tell exactly where it was coming from.
Any ideas as to where it could be coming from?
Here's a pic (sorry if it's lousy):
Here's another where you can also see my sweet ghetto heater cutoff valve. It makes the AC work a whole lot better because my heater didn't actually turn off all the way, at least not reliably. If anyone wants to try it I can dig out the part number I used and walk you through the install.
Last edited by Jesse's Town & Country; Aug 14, 2010 at 08:27 PM. Reason: added vehicle info
Old Aug 14, 2010 | 09:06 PM
blakels's Avatar
blakels
I had an '04 Neon that had a lot of fluid in the same area. It turned out to be from the coolant overflow bottle mounted to the cowl just above it. The trans cooler in the radiator had failed and the cooling system was full of ATF and vice-versa. Don't know where you're resovoir is but just a thought.
Old Aug 15, 2010 | 09:51 AM
That's a good thought, but no it's only ATF and the puke can is on the other end of the engine.
What's messing with me is that there really isn't much transmission above where its puddling, so there can't be too many places where it is coming from.
Old Aug 15, 2010 | 04:22 PM
mike bloom's Avatar
mike bloom
time to go to the parts store and buy a cheap black light kit. Put the dye in run it and see where your leak is coming from.
Old Aug 15, 2010 | 04:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
Go and get some anti foam and pour it in the transmission.This was a problem we had in the early 1990's.The transmission fluid would be so hot that it would come out of the vent tube. This could be were the fluid leak you are getting from.And if fluid is coming out of the missing bolt hole,then you may need to remove the transmission and found the leak.
Old Aug 15, 2010 | 11:39 PM
I could probably just find it visually if it weren't so danged cramped in there!
Hmm, where is the vent tube on this? It looks like there was oil coming out of the hole where the bolt is missing from that heater hose (any idea on the diameter, pitch, and length of that bolt btw?), but the greasy spot is fairly dry and covered with dust so that may be leftover from filling the transmission, it doesn't look like it is actively leaking there.
I don't think I have ever seen anything labeled as anti-foam at the parts store, is that something they will know if I ask? Do you recommend a specific one?
Old Aug 15, 2010 | 11:50 PM
master tech
The vent tube is also the shaft that comes out of the transmission case and double as the shifter.
Old Aug 16, 2010 | 03:19 PM
Well judging from the picture the oil isn't coming from the shifter shaft at the front of the transmission. If there were a hairline crack on top of the differential housing, could that be the problem?
Old Aug 16, 2010 | 04:20 PM
sapporo clean out your inbox!
Old Aug 16, 2010 | 08:44 PM
master tech
Sure it can.
