Crickets in the engine compartment in a 2002 Caravan SE 3.3 flex fuel.
Old Aug 19, 2010 | 09:04 AM
Iowajayhawker's Avatar
Iowajayhawker
Default Crickets in the engine compartment in a 2002 Caravan SE 3.3 flex fuel.
Ok so it's not really a cricket, at least I don't think so, but I do have an almost chirp like sound inthe engine compartment on the passenger side. I'm certain it's somthng belt driven, but I cannot narrow it down. I changed the water pump about a year ago, and both the idler and tensioner pulleys about 2 weeks ago. It starts when the engine starts, goes away at higher rpms, returns when I'm idling at a stop light, and ends when the engine is shut off. It's worse when the van is in gear, versus when in park or neutral. On a side note, it seems as if i'm getting low on freon, I do not know when it was last re-charged. Any help would be most appreciated.
Old Aug 19, 2010 | 10:01 AM
sapporo's Avatar
sapporo
take off belt and run for a few seconds to see if noise goes away. if so, then go onto checking moving parts like a/c pulley, alt etc. buy yourself an electronic ear from harbor freight and you can really pin point where noises are coming from
not your problem but I had a chevy truck that had a really annoying chirp. problem was a cracked power steering pulley
Old Aug 31, 2010 | 01:38 PM
Iowajayhawker
It is definitely something belt driven. I think it might be the ac clutch. It squeals really badly every once in awhile when we turn the ac on. Is there a way to test it, becasue from what I can tell it's a rather pricey part and I don't want to spend money if I do not need to.
If it is the ac clutch, what would be the best way to change it out?
Old Aug 31, 2010 | 06:45 PM
sapporo's Avatar
sapporo
did you investigate the alternator? before you post back, SEARCH this forum for Alternator issues!!!!!
when you engage the a/c you put more load on the electrical system (alternator)
you also MUST pull off the belt and do some hands on feel for diagnosis.
the BEST way to fix the a/c clutch is to have someone with the proper tools make the repair. if you don't have the right tools it will cost you 2-3x as much as if you had someone do it correctly
