How To Test Purge Solenoid
Old Aug 25, 2010 | 04:39 PM
vtjake's Avatar
vtjake
Post How To Test Purge Solenoid
Anyone know how to check the Purge Solenoid with a scanner? I read another post that said that you should not be able to blow or suck air through the solenoid. I tried that test and it seems OK, but, I was wondering if there was another way to check this part.
Thanks.
Jake
Old Aug 25, 2010 | 07:14 PM
sapporo's Avatar
sapporo
well, if you apply a vacuum to the intake manifold side of the valve, it will hold vacuum. then when you apply an electrical current to the valve it will open, dumping vacuum.
I personally use my scanner and have the computer control the application of the valve to verify that the PCM has control of this component
