Odometer Light stays on
Old Aug 24, 2010 | 11:21 PM
djm528's Avatar
djm528
Default Odometer Light stays on
I have a 98 Caravan and the odometer light stays on even when the Van is off. If I turn my headlights on the odometer light goes off. I was wondering if anyone can help me figure out what may be wrong. Any help would be appreciated.
Thanks,
Old Aug 24, 2010 | 11:41 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Are there any other lites staying on too?
Old Aug 25, 2010 | 12:52 AM
djm528's Avatar
djm528
No other lights. Just the odometer light.
Old Aug 25, 2010 | 09:25 PM
master tech
I have never seen this problem,Here is a couple of ideals. Ck the BCM for any codes. The ignition key in sense going to connector 2 LB wire pin#4, The ignition could be feeding voltage to the BCM and the also controls the cluster.or connector 4 pins #8 and #30 OR wire plugging into the back of the cluster E2.The headlamps are also controlled by the BCM too. But i would have the van ck'ed for codes first.
