No power to drivers side window on '04 Caravan
Old Sep 10, 2010 | 12:17 AM
Angie58's Avatar
Angie58
Question No power to drivers side window on '04 Caravan
The switch for the passenger window and door locks work. They are on same control panel. But the Driver's window control will not work. No sound at all. It worked one day, then 1/2 hour later it did not. I go through toll booths 2x a day, it's getting colder. I hope it is not a new motor. Someone told me that it may be a fuse, but where would that fuse be? Can you help? Please?
Old Sep 10, 2010 | 05:59 PM
Tizzy1's Avatar
Tizzy1
If the drivers side window doesn't work, very good chance it is the motor. Need to remove the door panel and check for power and ground at the motor connector.
Old Sep 16, 2010 | 03:12 AM
login1's Avatar
login1
Window regulator is gone. Can get the whole assembly for around $30 on Ebay. Very common issue.
Old Sep 21, 2010 | 11:10 AM
Mathew5655's Avatar
Mathew5655
I have the issue on the passenger side, do you have to replace the regulator and the motor or is there a way to just replace the motor? I'm not sure I can replace all the inside componets and cables and such, looks like a mess and very hard to get to. If so how can I remove the window from the regulator etc... Thanks
Old Sep 21, 2010 | 09:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
You need to replace the whole assy.But first ck for power and ground.
