Battery drains
Old Sep 15, 2010 | 05:25 PM
FRASER-VAN's Avatar
FRASER-VAN
Default Battery drains
I am sure that all lights are off, the radio is off, the key is off -- why is battery draining ?
So far I have taken ground cable off and inserted a meter to check while I take out the fuses and the relays to see which one indicates a drain.
I can also see a spark when I connect the + cable or - cable
Any more ideas on how to track this drain and stop it? Drains my battery overnight.
When I start the van the side lights are on but I cant find a switch to turn them off -- maybe that is problem?
thanks very much
Frz
Old Sep 15, 2010 | 06:18 PM
sapporo's Avatar
sapporo
everything you said is normal must need a new battery cuz you can have a battery that's bad inside dying like that.
Old Sep 15, 2010 | 06:34 PM
mfahey's Avatar
mfahey
A spark when reconnecting the cable is normal. You could remove one of the cables and leave it overnight. If the van still doesn't start in the morning, then you have a bad battery. You still may have a bad battery if the small amount of power that is drawn on a regular basis drains the battery overnight.
If you feel certain that the problem is still a matter of excess power being used when the van is off, you can try pulling fuses one at a time and see if that cures the problem which will help you narrow down where the problem is.
Old Sep 15, 2010 | 06:45 PM
sapporo's Avatar
sapporo
didn't he say in the first post he pulled relays and fuses?
Old Sep 15, 2010 | 10:50 PM
master tech's Avatar
master tech
Site Moderator & Tech
When connecting the battery,is the spark very big like you are trying to weld something? Or is it small.Also do you have a glove box lite, or is the dome lites working.The side marker lites should be off,even if you started the van. This could a bad BCM or an aftermarket alarm system.
Old Sep 16, 2010 | 12:40 PM
FRASER-VAN's Avatar
FRASER-VAN
SMALL
NO
OFF
THOUGHT THIS WAS A SAFETY FEATURE. CANT TURN THEM OFF. HOW?
WHAT IS BCM?
NO ALARM ... AFTERMARKET RADIO ? nope .. when disconnected I still have a little spark and volt meter shows a leak.
thanks
Old Sep 16, 2010 | 03:49 PM
FRASER-VAN's Avatar
FRASER-VAN
Solved! I think... The key was turned off but past the tiny marker to what could be an ACC. position.
Battery lasted the night without problem. So far so good
