Radiator Fan Airflow???
Old Sep 20, 2010 | 08:16 AM
rrc.swb's Avatar
rrc.swb
Default Radiator Fan Airflow???
Hi,
I'm looking for the technical specification for Mopar 4862624 dual electric fan.
Can anyone let me know the amps draw and cfm?
Thanks!!!
Old Sep 20, 2010 | 07:15 PM
sapporo's Avatar
sapporo
that's kind of an odd question. I highly doubt anyone on here would have that info. I'd try contacting Chrysler engineering directly.
Old Sep 21, 2010 | 12:22 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Idon't know if this is what you are looking for,This is from a 2002.
OPERATION
RADIATOR FAN OPERATION CHART COOLANT TEMPERATURE A/C PRESSURE TRANSAXLE OIL TEMPERATURE
Fan Operation Speeds: Initial Max Initial Max Initial Max
Fan On: 104°C (220°F) 110°C (230°F) Fan Speed Duty-Cycles (Ramps-up) from 30% to 99% 1,724 Kpa (250 psi) 2,068 Kpa (300 psi) Fan Speed Duty-Cycles (Ramps-up) from 30% to 99% 96°C (204°F) 111°C (232°F) Fan Speed Duty Cycles (Ramps-up) from 30% to 99%
Fan Off: 101°C (214°F) Fan Speed Duty-Cycles (Ramps-down) from 99% to 30% 1,710 Kpa (248 psi) Fan Speed Duty-Cycles (Ramps-down) from 99% to 30% 89°C (192°F) Fan Speed Duty Cycles (Ramps-down) from 99% to 30%
