2010 Caravan Towing Capacity
have at it.
I use to be opposed to using minivans used for towing, but after getting harassed and chastised, I'll just agree it'll be fine. but if it was me, I'd use a real truck or at the very least have brakes on the trailer. I guess all my years on the road (100,000 miles/yr) seeing the negative impacts of undersize vehicles towing oversize loads really hits a guy especially when taking evasive action to avoid running over an ejected occupant. (interstate 57 near marion, IL circa july 1995)
Hi , make sure to push your dash mounted traction control to lock out your overdrive as you will burn out your planitary or overdrive gear in your transmission if you tow in normal drive position . all the up - down shifting will wear out your trans very early !! You can spend a little more on gas now with higher r.p.m.'s or be left on the road with a tow & overhaul bill early in your trans's life . my thoughts Duane
