Caravan 2010 Tire and Rim Question
Old Oct 2, 2010 | 12:27 PM
aquaman8's Avatar
aquaman8
Default Caravan 2010 Tire and Rim Question
Hi all,
After buying new snow tires and rims for my 2002 Caravan last year, I decided that I needed a new Caravan this year!
The 2010 comes with 225/65R16 tires and the 2002 had 215/70R15 tires. Apart from the speedo on the 2010 showing a higher speed than actual, can I use the 215/70R15 on the 2010? Also, would the 2002 rims fit on the 2010, or is the bolt pattern different?
Thanks in advance for any help with this!
Mitch
Old Oct 2, 2010 | 02:31 PM
nsriar's Avatar
nsriar
i believe they changed the bolt pattern you will not be able to use your wheels. i think there is another thread which shows you bolt patter. in the forum page under grand caravan section click on search the forum and put in bolt patter it will bring in the post.
for 2002 model this is the pattern
2002 Dodge Grand Caravan
Bolt Pattern (in):
Bolt Pattern (mm):
Offset Range (mm):
Wheel Size Range (in):
Front Center Bore (mm):
Rear Center Bore (mm):
Stud_Size:
5x4.50
5x114.3
35 to 42
15x5.0 to 20x8.5
71.5
71.5
12x1.5
2002 Dodge Grand Caravan (AWD)
Bolt Pattern (in):
Bolt Pattern (mm):
Offset Range (mm):
Stud_Size:
5x4.50
5x114.3
35 to 42
15x5.0 to 20x8.5
71.5
71.5
12x1.5
for 2010 model i think its 5 x 127
Old Oct 2, 2010 | 03:31 PM
aquaman8's Avatar
aquaman8
Thanks so much for the response.
I'll do a search to verify but your idea of 5 x 127 sounds similar to what I had heard.
Now I need to source a 5 x 127 15" rim!!!!
Anyone have any ideas where to try?
Mitch
