2010 4.0l transmission shifting problems
Old Oct 5, 2010 | 01:56 PM
born2fishnfl's Avatar
born2fishnfl
Default 2010 4.0l transmission shifting problems
Experiencing two issues. First, when shifting from reverse to drive (and vice versa), majority of the time the trans slams into gear. Come to a dead stop after backing out of the driveway, pull shifter down to "D" and bam. Feels like the trans is about to drop out of the van.
Second issue while driving. When shifting from 1st to 2nd, theres a slight hesitation, then shifting from 2nd to 3rd, it feels like the trans shutters, like it is trying to find the gear. From 3rd on, the trans shifts smooth as silk.
Van has only 4,500 miles on it and plan on bringing it up at next service, but wanted to see if anybody else has (or had) the same issue so hopefully I could point the sevice department in the right direction.
thanks in advance
Old Oct 5, 2010 | 04:17 PM
2010SXT4.0L's Avatar
2010SXT4.0L
Nothing like that here but keep us updated and good luck
Old Oct 5, 2010 | 07:27 PM
amgp's Avatar
amgp
I haven't experienced anything like that either, but mine only has a couple of hundred miles on it...
Please let us know what you find out.
Old Oct 7, 2010 | 11:24 AM
gentz's Avatar
gentz
6 speed tranny hehe..same problem here with my 08, tranny had to be replaced.. You have problems inside the transmission.
Old Oct 7, 2010 | 11:51 AM
blubomber's Avatar
blubomber
born2fishnfl, i have an '09 with the 3.8L and i have the same issues going from 1st to 2nd and then from 2nd to 3rd. I have had it looked at by the local dealer twice and they said they are not getting an error code so there is nothing they can do. I bought the van used and it has just over 40,000 miles on it. I did get an extended warranty for the next three years so hopefully i can get it figured out by then.
gentz, how did you come to the conclusion your tranny needed to be replaced? What tests were done?
Thanks
Old Oct 7, 2010 | 02:00 PM
born2fishnfl
I'll keep all posted...still have 1,000 miles until the next service. My issue with the trans shifting hard and shuttering, is the fact that other parts of the drivetrain are receiving additional stress and what about if or when I try to sell it? Anybody test driving it will feel it.
Old Oct 8, 2010 | 10:50 AM
gentz's Avatar
gentz
blubomber, if no error codes are found, the latest flash performed then a tear down is required. Then the techs that do the teardown if good will find whats wrong. Just a word of caution...alot of dealer techs are not that experienced...my word find a good dealership with experienced techs.
