Owners Manual !!!
Hi , The "low fuel light" on my brand new Dodge Caravan comes on @ 3 gallons or about 60 miles left in your tank . The owners manual is about sorry & says nothin about the light an very little about the other warning lights !!!!!!! My Thoughts Duane
Hope this helps in some way.
FUEL
The fuel gauge gives an indication to the vehicle operator of the level of fuel in the fuel tank. This gauge is controlled by the instrument cluster circuit board based upon cluster programming and electronic fuel level messages received by the cluster from the Totally Integrated Power Module (TIPM) over the CAN data bus.
The fuel gauge is driven by an electronic stepper motor unit that receives battery current on the instrument cluster electronic circuit board through the fused ignition switch output (run-start) circuit whenever the ignition switch is in the ON or START positions. The cluster is programmed to move the gauge needle back to the low end of the scale after the ignition switch is turned to the OFF position. The instrument cluster circuitry controls the gauge needle position and provides the following features:
Fuel Level Message - The TIPM provides a constant current source to the fuel level sending unit and monitors a return input on a fuel level sense circuit. The resistance through the fuel level sending unit increases as the fuel level rises and decreases as the fuel level falls causing changes in the fuel level sense input voltage. The TIPM then sends the appropriate electronic fuel level messages to the cluster. The cluster programming applies an algorithm to calculate the proper fuel gauge needle position based upon the fuel level message input, then moves the gauge needle to the proper relative position on the gauge scale. This algorithm is used to dampen gauge needle movement against the negative effect that fuel sloshing within the fuel tank can have on accurate inputs from the fuel tank sending unit to the TIPM.
Less Than 11 Percent Tank Full Message - Each time the fuel level message to the cluster indicates the fuel tank is about 11 percent full or less for 10 consecutive seconds and the vehicle speed is zero, or for 60 consecutive seconds and the vehicle speed is greater than zero, the gauge needle is moved to about the one-sixteenth graduation on the gauge scale, the low fuel indicator is illuminated, and a single chime tone is sounded. The low fuel indicator remains illuminated until the fuel level message indicates that the fuel tank is greater than about 14 percent full for 10 consecutive seconds and the vehicle speed is zero, or for 60 consecutive seconds and the vehicle speed is greater than zero, or until the ignition switch is turned to the OFF position, whichever occurs first. The chime tone feature will only repeat during the same ignition cycle if the low fuel indicator is cycled OFF and then ON again by the appropriate messages from the TIPM.
Less Than Empty Stop Message - Each time the cluster receives a fuel level message indicating the fuel level in the fuel tank is less than the E (or Empty) gauge needle stop position for five consecutive seconds, the gauge needle is moved to the low end of the gauge scale and the low fuel indicator is illuminated immediately. This input would indicate that the fuel level sense input to the TIPM is a short circuit.
More Than Full Stop Message - Each time the cluster receives a fuel level message indicating the fuel level in the fuel tank is more than the F (or Full) gauge needle stop position for ten consecutive seconds, the gauge needle is moved to the low end of the gauge scale and the low fuel indicator is illuminated immediately. This input would indicate that the fuel level sense input to the TIPM is an open circuit.
Self-Test - Each time the cluster is put through the self-test, the fuel gauge needle will be swept to several calibration points on the gauge scale in a prescribed sequence in order to confirm the functionality of the gauge and the cluster control circuitry.
The TIPM continually monitors the fuel tank sending unit to determine the level of fuel in the fuel tank. The TIPM then sends the proper electronic fuel level message to the EMIC and other electronic modules in the vehicle over the CAN data bus. The TIPM will store a Diagnostic Trouble Code (DTC) for any fault detected in the fuel level sense circuit.
FUEL
