power steering....
Old Oct 26, 2010 | 11:42 AM
ecoli_23's Avatar
ecoli_23
Default power steering....
98 Grand Caravan.....got a serious leak..like a qt every few days......crawled under and the bolt on the passenger side ez to get to......the one on the drivers doesnt look very ez...
any tips or tricks to get the bolt off on the drivers side?
Old Oct 26, 2010 | 12:10 PM
dakota_raven's Avatar
dakota_raven
Are you sure is the power steering pump that is leaking? My wife's 2000 Caravan was doing that and it turns out that was the power steering pressure line. Just double check before you spand the the money in a new pump. Just my 2 cents.... Good luck!!!
Old Oct 26, 2010 | 06:59 PM
ecoli_23's Avatar
ecoli_23
yea thought i had said that...i have the line ordered and it should be in today.....the bolt for the line on pass. side will be ez...the other one will be a pain...any tips?
Old Oct 26, 2010 | 11:29 PM
master tech's Avatar
master tech
Site Moderator & Tech
If it the line going into the rack n pinion. 18mm flare or wrench,you may need to drop the LDP pump.
