Caravan no heat on passenger side
Hello, My brother has a caravan, 2000 year i beleive or just a year or two newer. He gets heat on the drivers side but not the passenger side, it is the one that has the duel climate controls. I am looking for all things to check and look for, he stated that a mechanic told him he needed something that cost appx 500.00 dollars. But reading on the site, some are stating that there might be a reset to calibrate the blend doors?? any help would be most helpful...thanks
need the exact year for diagnistic tests.
I dont think 2000 had dual climate controls(or i havent seen one with that option)
maybe T&C had this option, my guess its a 2001-2007?
find out and we can go from there
Go up to the diy section and Master Tech has posted the system recalibration test and the head diagnostics for the control head. Usually the slider craps out so it doesn't see you move the lever. The self test diagnostics will show you if that is the case. After the calibration is done, you can enter diagnosic mode and test all the slides and mode ****.
Trending Topics
@ Tizzy and Hemi, thank for all you help in this matter. I did the test and everything past, I think. anyway went to recycle yard and behold, there was a donor exact fit and numbers matched. installed it, ran the test and calibration and BooYaaaa.... We got heat!!! all over...... again thanks you and all the other family that assisted in this matter....
