2003 caravan no ground on asdl relay
Old Nov 14, 2010 | 10:15 AM
unclenuggy's Avatar
unclenuggy
Default 2003 caravan no ground on asdl relay
i have no ground on my eaxt auto shut down relay and my asdl relay, when i ground them out manually on the battery they work, was wondering if it was a ground issue on my fuse panel
Old Nov 14, 2010 | 08:23 PM
mfahey's Avatar
mfahey
Ground comes from the PCM so either there is a wiring issue, a problem with the PCM itself or the conditions that the PCM needs to see to activate the relays have not been met.
Old Nov 14, 2010 | 09:20 PM
master tech's Avatar
master tech
Site Moderator & Tech
What can do is find the ground circuit at the pcm and the ground at the asd relay. ck the ohm resisted. If its open, run a wire overlay from the pcm to the ground side of the asd relay.
