Temp Guage Going Hot
Old Nov 17, 2010 | 07:16 PM
Cdn-Van's Avatar
Cdn-Van
Default Temp Guage Going Hot
The temp gauge on my 2001 caravan is now going from cold to hot shortly after starting up my van but the engine is not blowing heat. The warning light is coming on. The temp gauge starts to drop, but then goes back up.
Van isn't leaking and the rad hoses feel full.
Fan is kicking in and running.
Is the t-stat gone or something else?
Old Nov 17, 2010 | 08:32 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
i think bad t stat but they ussually fail open so ya show colder temps
Old Nov 18, 2010 | 12:37 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Could be the T-stat or blowen head gaskets. Try a T-stat first.
Old Dec 10, 2010 | 04:36 PM
Cdn-Van's Avatar
Cdn-Van
Default New t-stat and rad, but problem not fixed.
Thanks for the help.
After two trips to the garage, the problem still isn't fixed.
The dealer first replaced the t-stat and the fan relay.
Things seemed ok for 3 weeks but there was no heat.
Problem returned. Dealer checked the head gasket and everything seemed fine. Dealer checked the water pump, but said the pump is working ok. Checked t-stat and it was working as well.
Mechanic said that there seemed to be too much fluid in the resevoir and that ther must be a blockage in the system. Replaced the rad, and things were ok for about 100 miles. Heater stopped blowing heat and then the temp gauge started spiking.
The problem only happens when driving the van.
Any suggestions
Old Dec 10, 2010 | 11:27 PM
master tech
Is the fan in the fan module coming on?
