Heater blows warm
Old Dec 1, 2010 | 07:41 AM
wkweir's Avatar
wkweir
Default Heater blows warm
Hi, I hope someone can help me. I have a 1994 grand caravan where the heat only blows warm but when I turn the blower fan off and turn it on it will blow hot and then go back to warm. This does this both at idle and driving. Temp. gauge reads normal. Coolant level is full and have leaked any coolant. Any suggestions would be greatly appreciated. Oh I forgot to mention I have removed a defective heater control valve and ran the heater hose straight to the heater core and plugged the vacuum line.
Thanks
Wkweir
Old Dec 1, 2010 | 07:53 AM
hemi4spd's Avatar
hemi4spd
for the 10 bucks they r worth, id put a new Tstat in it,
are the hoses to the heater core hot to touch?
Old Dec 1, 2010 | 09:46 AM
wkweir's Avatar
wkweir
both hoses get hot
Old Dec 1, 2010 | 03:35 PM
Tizzy1's Avatar
Tizzy1
If both hoses are very hot to the touch, then most likely a blend door issue. Can you hear the door "thunk" when you move it all the way to hot? If not, it is a cable operated blend door and the cable is adjustable.
Old Dec 1, 2010 | 07:58 PM
sapporo's Avatar
sapporo
Pay up.
I'm in favor of the blend air door.
Old Dec 1, 2010 | 08:03 PM
hemi4spd's Avatar
hemi4spd
lol make cheque payable to????
well with the additional info would suggest good stat,
obviously in the heater box
Old Dec 1, 2010 | 08:48 PM
sapporo's Avatar
sapporo
stat would be a waste of money if the cooling system is reaching and maintaining normal temp. (this would need to be verified with a pyrometer or using a scanner to read the ECT value.
