shuts off while driving
Old Dec 11, 2010 | 11:23 AM
flyman426's Avatar
flyman426
Default shuts off while driving
More problems, after installing a new starter last nite and thinking all was well, today the van quit running two times while driving. The codes were 1389 1684, Please help!!!!!!!!!!!!!! Ready to burn to the ground!!!!!!!!!!!
Old Dec 12, 2010 | 01:17 AM
master tech's Avatar
master tech
Site Moderator & Tech
Here is part of the pdf file for code P1389.
Symptom:
P1389-NO ASD RELAY OUTPUT VOLTAGE AT PCM
When Monitored and Set Condition:
When Monitored: With ignition key on. Battery voltage greater than 10 volts.
Set Condition: No voltage sensed at the PCM when the ASD relay is energized.
POSSIBLE CAUSES
INTERMITTENT CONDITION
ASD RELAY
FUSED B+ CIRCUIT
ASD RELAY OUTPUT CIRCUIT OPEN (NO START)
IPM FUSE & RELAY CENTER
PCM START
PCM
TEST ACTION APPLICABILITY
1 NOTE: Inspect the ASD Relay fuse located in the IPM. If the ASD Relay fuse
is open, repair the cause of the open first before continuing. Inspect theASD
Relay Output circuit for a short to ground for the cause of the open fuse.
NOTE: Diagnose P1388 - Auto Shutdown Relay Control Circuit first if set
along with this DTC.
With the DRBIIIt, erase the DTC.
Attempt to start the engine. If the engine will not start, crank the engine for at least
15 seconds. It may be necessary to repeat several times.
Does the DTC reset.
All
Yes ® Go To 2
No ® Go To 9
2 Attempt to start the engine.
Does the engine start.
All
Yes ® Go To 3
No ® Go To 5
196
DRIVEABILITY - GAS
