96 grand caravan tranny into an 02
Old Dec 20, 2010 | 09:41 PM
Zak62592's Avatar
Zak62592
Default 96 grand caravan tranny into an 02
I might be getting my hands on a transmission that actually works (wow!) from a 96 grand caravan that's being scrapped. However there's this 02 grand caravan that's been sitting for a while and is in perfect condition, however the tranny went in that one too.
NOTE: the 96 has a 3.3, and i believe the 02 has a 3.8 but i'm not completely sure. If they both have the 41te i'm assuming they have the same bellhousing and whatnot. Would this be a doable conversion?
Old Dec 20, 2010 | 10:35 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
It could work. But need to make some changes, TRS connector, Flex plate that bolts to the torque converter and the fittings for the cooler lines if needed,
Old Jan 3, 2011 | 08:43 PM
corbitext's Avatar
corbitext
Hi Zac62592 what is the update of your work did you transfer the 02 tranny to 96?
Thanks a lot, I appreciate if you can share your experience?
