Issue after I add gas to fuel tank
2005 Grand Caravan SXT - 93000 miles
For the last few months whenever I add gas to the tank (and particularly when gas was below 1/4 tank before fill up) the engine sputters and starts to stall. Revving the engine appears to correct issue. My initial thought was fuel filter?
Read this post. It describes your problem to a "T".
http://www.ricksfreeautorepairadvice...rysler-minivan
DIY'ing a new tank isn't difficult. Time consuming, yes. Expensive, yes. As far as damage.....during that sputtering, (if the cause is really a saturated charcoal canister), the engine is running really rich. That extra fuel can damage the catalytic converter IF it goes on a for long time. But it doesn't sound like that's happening in your case, since the engine isn't stalling and the problem seems to go away after you goose it. However, if the check engine light ever starts blinking, that's a sign of a serious catalytic converter problem. If it were my vehicle and I was strapped for cash, I'd leave it alone. Try re-filling at 1/2 tank instead of 1/4 and see if that makes a difference. Good luck. Report back if anything changes.
I am having the same problem with my van and I posted it in this forum but did not get a good answer. Thanks for your reply to nazran I now know the fix to my problem.
My van will miss fire for about 1 second after about 1 minute after fueling. This may happen 2 or three times. If the engine is at idle it may stall but will restart easily. This does not happen every time, perhaps 3 out of 4 fillings. I do stop filling the tank when the nozzel clicks off. Maybe not filling the tank completly will help.
Replacing the tank is not an option that I want to do. I seems stupid to replace the tank to fix a valve. Can the valve be cleaned or repared?
Trending Topics
