2005 Grand Crvn
Old Jan 1, 2011 | 07:21 PM
leighbrn's Avatar
leighbrn
Default 2005 Grand Crvn
Hi Guys,
I have a problem that I cannot seem to track down. Last night, I was driving my van, and everything was working perfectly. Came home, and 45 minutes later, went out to start the van, and it coughed and quit. I tried to start a few times, and nothing. Now, it cranks, but doesn`t catch at all. I checked and I have spark at the plugs. The plug seemed very dry to me. It is a 2005 Dodge Grand Caravan with a 3.3L and no real problems other than I changed out the EGR last summer. Unfortunately, it won't start, so I cannot take it somewhere to have any codes checked.
Any ides?
Old Jan 1, 2011 | 07:26 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Ck to see if you have spark at the plugs and then ck for fuel from the fuel rail. Or take the air filter housing lid off and spay carb cleaner into the throttle and try to start. If it starts, then the fuel pump maybe your problem why it won't start.
Old Jan 2, 2011 | 03:02 PM
leighbrn's Avatar
leighbrn
Hi master tech,
Thanks for the reply. I checked the electrical supply to the fuel pump, and there is electricity getting there when the key is turned on. I removed the fuel pump, and applied 5 volts to it, and it spins. However, when I disconnect the fuel line quick connect near the air intake, no fuel comes out when the key is turned over. Does that mean the fuel pump is shot, even though it still turns? I did the quick start in the intake past the butterfly and it would start up ever so briefly. So, I am getting spark. any thoughts? Do you think the pump is shot?
Thanks so much for your help and insight.
Leigh
Old Jan 2, 2011 | 03:08 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
fuel filter plugged? check pressure on the rail?
Old Jan 2, 2011 | 04:10 PM
leighbrn's Avatar
leighbrn
The fuel filter is part of the pump, but it appears to be ok. I will have to check pressure at the fuel rail.
Thanks.
Old Jan 2, 2011 | 04:20 PM
hemi4spd's Avatar
hemi4spd
filter or pressure regulator would be what I'd be lookin at
also pumps can spin and sound like they are working but no fuel out the line says it may not be working
if you got no fuel coming out the line at fuel rail I'll tell you now the pressure test will be zero
you say the pump/filter appears to be ok, have you pulled the pump?
Old Jan 2, 2011 | 04:58 PM
leighbrn's Avatar
leighbrn
Yeah, pulled the pump out of the tank. Me thinks the pump is shot, since I am not getting fuel at the rail. Just hestitant to drop $350 for a fuel pump, if it really isn't the problem.
I did find a used one at the local wrecker for $60. Is it worth trying a used one?
Thanks,
Old Jan 2, 2011 | 05:53 PM
trophyslayer's Avatar
trophyslayer
here was a thread saying how there is a safety valve in the fuel line
https://dodgeforum.com/forum/dodge-c...-no-start.html
here is his post
Originally Posted by cstirnfst
Quick update. The Caravan is now running fine. I learned that the fuel line that connects to the fuel rail has a safety valve inside that was preventing any fuel (or air) from getting through it while it was disconnected. This valve opens when it is connected by the metal line on the fuel rail. Looks like I learned something new :-)
Anyways, had it towed by AAA to a shop who charged the dead battery (from constantly trying to start it) and it started right up for him. My guess is that water from recent rains drenched some wiring. The last time I drove it fine was in the rain. The next morning it wouldn't start. The weatherstripping at the back side of the hood blew off recently so any rain can fall on the engine.
By the time it got to the shop the wires/conponents had dried enough to start like normal. At least that's what it looks like. Thanks everyone for your help.
Nathan
I too had problems with a battery that would work 1 time then 10mins not work
not sure how old you battery is, but sure would be cheaper
Old Jan 2, 2011 | 08:00 PM
leighbrn's Avatar
leighbrn
Yeah, looked into that thread. I am certain that it is not electrical, as there is power making it's way to the fuel pump, when the key is turned. I definitly don't hear what he described as hearing the pump priming itself. That is what is swaying me towards the pump being shot.
Anyway, wondering if a used pump from the wrecker would be an alternative?
Thanks,
Old Jan 3, 2011 | 07:41 PM
vangonebuy's Avatar
vangonebuy
Something not mentioned here. Try another key. 2005 have chip keys.
If you are getting a small red indicator light on your dash, with no indicators to explain itself. It's the chip inside the key.
Usually the car will catch and stall in 2-3 sec's. But it could explain the electronic pumps not working.
Hey, It's a cheap long shot.
