Front end
Old Jan 14, 2011 | 02:42 PM
tinmann's Avatar
tinmann
Default Front end
I've got a 2000 caravan 3.3l 116k. The front end has been making a noise over bumpy roads. So I checked the shocks which are ok, the struts were replaced at about between 80k-90k. I was thinking it might be the ball joints.
I get the vehicle up to check on the ball joints and they seem fine. I checked the wheelbearing for play and that is ok. The thing I did notice is that as I checked the wheel @ 3 and 9 oclock I was getting some play there. Any help is appreciated.
Thanks
Old Jan 14, 2011 | 09:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
That could be outer or inner tie rod end. But i would also ck the sway bar bushing and links too.
Old Jan 16, 2011 | 12:55 AM
vistal's Avatar
vistal
Sometimes you wont see the strut mounts have gone bad too. I just had my read shock bolt brake cus i used the original one which was worn out. Also check your innner and outer tirods
Old Apr 12, 2012 | 04:09 PM
C210M's Avatar
C210M
How do you check sway bar bushings? I replaced the sway bar links and got rid of some of the noise, but still have a groaning sound when the suspension goes up and down
Old Apr 12, 2012 | 04:36 PM
papaduck's Avatar
papaduck
There shold be no up and down movement where the sway bar is attached to the frame.
Old Apr 13, 2012 | 04:44 PM
C210M's Avatar
C210M
Okay, thanks. Is it a tough job to change the sway bar bushings
Old Apr 14, 2012 | 08:17 AM
papaduck's Avatar
papaduck
No it isn't hard. If you have a deep well socket or a box end ratchet it will make the the change much quicker. Only 1 long stud on each bracket and the nut is self locking. The rubber bushings are split and with force can be slipped over the sway bar.
