Throttle body cleaning
06 caravan 3.8---should i use carb cleaner to remove any build up by the butterfly near within the thottle body? Just a little spray and clean it.
I am not having any problems--just for mainteance?
I use carb cleaner too, with a rag.Unless the throttle body is really gum up, then i remove the throttle body and the TPS and idle speed motor and it good with a tooth bush and carb cleaner.
YIKES PAPADUCK! Don't spray silicone in there. That'll ruin the Oxygen sensor.
Excerpt from the web:
What will damage my O2 sensor?
Home or professional auto repairs that have used silicone gasket sealer that is not specifically labeled "Oxygen sensor safe", "Sensor safe", or something similar, if used in an area that is connected to the crankcase. This includes valve covers, oil pan, or nearly any other gasket or seal that controls engine oil.
